Datasheet Texas Instruments ADS8405IPFBR — Даташит
Серия | ADS8405 |
Модель | ADS8405IPFBR |
16-разрядный АЦП с униполярным входом и частотой дискретизации мощности 1,25 MSPS 48-TQFP от -40 до 85
ADS8405: 16-Bit, 1.25-MSPS Unipolar Pseuso-Diff Input, Micropower Sampling ADC datasheet
PDF, 1.7 Мб, Файл опубликован: 17 дек 2004
![]() 13 предложений от 12 поставщиков Микросхема Преобразователь AD, Analog to Digital Converter 16Bit 1.25MSPS Unipolar Input Micro Power Sampling ADC ADC Single SAR 1.25MSPS 16Bit Parallel... | |||
ADS8405IPFBR Texas Instruments | 2 105 ₽ | ||
ADS8405IPFBR Texas Instruments | 2 454 ₽ | ||
ADS8405IPFBR Texas Instruments | 3 070 ₽ | ||
ADS8405IPFBR | 144 077 ₽ |
Pin | 48 |
Package Type | PFB |
Industry STD Term | TQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | ADS8405I |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Analog Voltage AVDD(Max) | 5.25 В |
Analog Voltage AVDD(Min) | 4.75 В |
Архитектура | SAR |
Digital Supply(Max) | 5.25 В |
Digital Supply(Min) | 2.7 В |
INL(Max) | 2 +/-LSB |
Input Range(Max) | 4.2 В |
Тип входа | Pseudo-Differential,Single-Ended |
Integrated Features | Oscillator |
Interface | Parallel |
Multi-Channel Configuration | N/A |
Package Group | TQFP |
Package Size: mm2:W x L | 48TQFP: 81 mm2: 9 x 9(TQFP) PKG |
Power Consumption(Typ) | 155 mW |
Rating | Catalog |
Reference Mode | Ext,Int |
Разрешение | 16 Bits |
SINAD | 85 дБ |
SNR | 86 дБ |
Sample Rate (max) | 1.25MSPS SPS |
Sample Rate(Max) | 1.25 MSPS |
THD(Typ) | -90 дБ |
- Using ADS8411 in a Multiplexed Analog Input Application (Rev. A)PDF, 2.1 Мб, Версия: A, Файл опубликован: 15 фев 2006
This application report is intended as a guide for using an analog multiplexer to multiplex several input signals to a single high-resolution, high-speed SAR analog-to-digital converter (ADC). The ADC and the multiplexer used were the ADS8411 and the TS5A3159/3359, respectively. This document discusses the important parameters of a multiplexer and defines a few important measurements for evaluatin - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8405 (6)
- ADS8405IBPFBR ADS8405IBPFBT ADS8405IBPFBTG4 ADS8405IPFBR ADS8405IPFBT ADS8405IPFBTG4
