Datasheet Texas Instruments TCA4311ADGKR — Даташит
Серия | TCA4311A |
Модель | TCA4311ADGKR |
Буферы 2-проводной шины с возможностью горячей замены 8-VSSOP от -40 до 85
TCA4311A Hot Swappable 2-Wire Bus Buffers datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 июн 2014
![]() 30 предложений от 17 поставщиков Чип интерфейса, I2C Buffer 3.3V/5V 8Pin VSSOP | |||
TCA4311ADGKR Texas Instruments | 49 ₽ | ||
TCA4311ADGKR Texas Instruments | от 261 ₽ | ||
TCA4311ADGKR Texas Instruments | по запросу | ||
Pin | 8 | 8 | 8 | 8 | 8 | 8 |
Package Type | DGK | DGK | DGK | DGK | DGK | DGK |
Industry STD Term | VSSOP | VSSOP | VSSOP | VSSOP | VSSOP | VSSOP |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R | LARGE T&R | LARGE T&R | LARGE T&R | LARGE T&R |
Маркировка | 6K6 | 6KE | 6KS | 6KA | 6KU | 6KF |
Width (мм) | 3 | 3 | 3 | 3 | 3 | 3 |
Length (мм) | 3 | 3 | 3 | 3 | 3 | 3 |
Thickness (мм) | .97 | .97 | .97 | .97 | .97 | .97 |
Pitch (мм) | .65 | .65 | .65 | .65 | .65 | .65 |
Max Height (мм) | 1.07 | 1.07 | 1.07 | 1.07 | 1.07 | 1.07 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать | Скачать | Скачать |
Channel Width | 2 |
Master Side I2C Bus Capacitance Supported | 400 пФ |
Max Frequency | 400 kHz |
Количество выходов | 2 |
Package Group | VSSOP |
Slave Side I2C Bus Capacitance Supported | 400 пФ |
Special Features | Enable Pin,Open-Drain I/O Type |
VCC(Max) | 5.5 В |
VCC(Min) | 2.7 В |
fSCLK(Max) | 0.4 МГц |
- Evaluation Modules & Boards: TMDXEVM388
DM388 DaVinci Digital Media Processor Evaluation Module
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TCA4311A (2)
- TCA4311ADGKR TCA4311ADR
- Semiconductors > Interface > I2C > I2C Level Shifters, Buffers, and Hubs
