Datasheet Texas Instruments SN74LVC1G00DBVTG4 — Даташит
СерияSN74LVC1G00
МодельSN74LVC1G00DBVTG4
Одиночный 2 входа, положительный логический элемент NAND 5-SOT-23 от -40 до 125
SN74LVC1G00 Single 2-Input Positive-NAND Gate datasheet
PDF, 1.5 Мб, Версия: AB, Файл опубликован: 23 апр 2014
Микросхема Логический чип, NAND Gate 1Element 2IN CMOS 5Pin SOT-23 T/R
SN74LVC1G00DBVTG4
35 ₽
SN74LVC1G00DBVTG4
SN74LVC1G00DBVTG4
TradeElectronics
SN74LVC1G00DBVTG4
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаC00F
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeNAND
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,Small DPW package,low power
Sub-FamilyNAND Gate
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)9,5.5,4.7,4 нс
  • NanoStarв„ў & NanoFreeв„ў 300Ојm Solder Bump WCSP Application
    PDF, 749 Кб, Файл опубликован: 2 фев 2004
    The NanoStarв„ў Wafer Chip-Scale Package (WCSP) is a family of bare die packages developed for applications that require the smallest possible package. WCSP provides electrical interconnection via solder spheres attached to the die and is aligned with JEDEC package standard MOв€’211. NanoStarв„ў, with advanced materials engineering technology, has demonstrated excellent board level rel
  • Designing and Manufacturing with TI's X2SON Packages
    PDF, 134 Кб, Файл опубликован: 23 авг 2017
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G00DBVTG4
