Datasheet Texas Instruments SN74LVC112ADT — Даташит
СерияSN74LVC112A
МодельSN74LVC112ADT
Двойной триггер JK, запускаемый отрицательным фронтом, с прозрачным и предустановленным 16-SOIC от -40 до 125
SN74LVC112A Dual Negative-Edge-Triggered J-K Flip-Flop With Clear And Preset datasheet
PDF, 980 Кб, Версия: M, Файл опубликован: 26 дек 2014
30 предложений от 16 поставщиков
Микросхема Бистабильный мультивибратор, Flip Flop JK-Type Neg-Edge 2Element 16Pin SOIC T/R
SN74LVC112ADT
27 ₽
SN74LVC112ADT
105 ₽
SN74LVC112ADT
115 ₽
SN74LVC112ADT
от 126 ₽
Pin16
Package TypeD
Package QTY250
CarrierSMALL T&R
МаркировкаLVC112A
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Bits2
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)2 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.8 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Flip-Flop/Latch/Register > J-K Flip-Flop
На английском языке: Datasheet Texas Instruments SN74LVC112ADT
