Datasheet Texas Instruments OPA2301AIDGKR — Даташит
Серия | OPA2301 |
Модель | OPA2301AIDGKR |
Малошумящий, высокоскоростной, 16-битный операционный усилитель КМОП 8-VSSOP от -40 до 125
Low-Noise, High-Speed,16-Bit Accurate, CMOS Operational Amplifier datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 13 июн 2007
![]() 16 предложений от 14 поставщиков Микросхема Буферный усилитель, Low-Noise, High-Speed, 16Bit Accurate CMOS Operational Amplifier 8-VSSOP -40℃ to 125℃ | |||
OPA2301AIDGKR Texas Instruments | от 37 ₽ | ||
OPA2301AIDGKR Texas Instruments | 75 ₽ | ||
OPA2301AIDGKR Rochester Electronics | от 103 ₽ | ||
OPA2301AIDGKR Texas Instruments | 135 ₽ |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | OAWM |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | CMOS |
CMRR(Min) | 66 дБ |
CMRR(Typ) | 80 дБ |
GBW(Typ) | 150 МГц |
Input Bias Current(Max) | 5 pA |
Iq per channel(Max) | 12 мА |
Iq per channel(Typ) | 9.5 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 2.5 uV/C |
Output Current(Typ) | 70 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 80 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 3 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 5 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2301 (6)
- OPA2301AID OPA2301AIDG4 OPA2301AIDGKR OPA2301AIDGKT OPA2301AIDGKTG4 OPA2301AIDR
