Datasheet Texas Instruments SN74LVC08ADR — Даташит
Серия | SN74LVC08A |
Модель | SN74LVC08ADR |
Четверной 2-входовой логический элемент «И» 14-SOIC от -40 до 125
SN74LVC08A Quadruple 2-Input Positive-AND Gates datasheet
PDF, 1.4 Мб, Версия: S, Файл опубликован: 11 авг 2015
![]() 60 предложений от 28 поставщиков Логический элемент И, семейство LVC, 4 элемента, 2 входа, 24мА, 1.65В до 3.6В, SOIC-14 | |||
SN74LVC08ADR Texas Instruments | 1.03 ₽ | ||
SN74LVC08ADR Texas Instruments | 5.48 ₽ | ||
SN74LVC08ADR Texas Instruments | от 13 ₽ | ||
SN74LVC08ADR Texas Instruments | от 14 ₽ |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | LVC08A |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 4 |
ICC @ Nom Voltage(Max) | 0.01 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 9.8,6.9,4.8,4.1 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74LVC08A (27)
- HVAL02231ARGYR SN74LVC08AD SN74LVC08ADBLE SN74LVC08ADBR SN74LVC08ADBRE4 SN74LVC08ADBRG4 SN74LVC08ADE4 SN74LVC08ADG4 SN74LVC08ADR SN74LVC08ADRE4 SN74LVC08ADRG3 SN74LVC08ADRG4 SN74LVC08ADT SN74LVC08ANSR SN74LVC08ANSRE4 SN74LVC08APW SN74LVC08APWE4 SN74LVC08APWG4 SN74LVC08APWLE SN74LVC08APWR SN74LVC08APWRE4 SN74LVC08APWRG3 SN74LVC08APWRG4 SN74LVC08APWT SN74LVC08APWTG4 SN74LVC08ARGYR SN74LVC08ARGYRG4
- Semiconductors > Logic > Gate > AND Gate
