Datasheet Texas Instruments OPA121KM — Даташит
СерияOPA121
МодельOPA121KM
Недорогой прецизионный операционный усилитель Difet 8-TO-99
Low Cost Precision Difet® Operational Amplifier datasheet
PDF, 500 Кб, Файл опубликован: 27 сен 2000
24 предложений от 15 поставщиков
Микросхема Операционный усилитель, Op Amp Single GP ±18V 8Pin TO-99
Зенер
Россия и страны ТС
OPA121KMот 2 343 ₽
OPA121KMот 4 933 ₽
OPA121KM-1по запросу
TradeElectronics
OPA121KMпо запросу
Package TypeLMC
Industry STD TermTO-CAN
JEDEC CodeO-MBCY-W
Width (мм)9.08
Length (мм)9.08
Thickness (мм)4.4
Pitch (мм)2.54
Max Height (мм)5.72
Рекомендуемая замена
ReplacementOPA121KU
Replacement CodeF
Additional FeaturesVos Adj Pin
Approx. Price (US$)6.16 | 1ku
АрхитектураFET
CMRR(Min)(dB)82
CMRR(Typ)(dB)100
GBW(Typ)(MHz)2
Input Bias Current(Max)(pA)5
Iq per channel(Max)(mA)4
Iq per channel(Typ)(mA)2.5
Number of Channels(#)1
Offset Drift(Typ)(uV/C)3
Output Current(Typ)(mA)40
Rail-to-RailNo
Slew Rate(Typ)(V/us)2
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)10
Vn at 1kHz(Typ)(nV/rtHz)8
Vos (Offset Voltage @ 25C)(Max)(mV)2
RoHSНе совместим
  • Diode-Connected FET Protects Op Amps
    PDF, 49 Кб, Файл опубликован: 2 окт 2000
    Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step.
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA121KM
