Datasheet Texas Instruments 5962-8780401CA — Даташит
СерияSN54AS21
Модель5962-8780401CA
Двойные 4-входовые логические элементы положительного И 14-CDIP от -55 до 125
Datasheet
TSP
T-electron
5962-8780401CA
Pin14
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.67
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Live Insertion
Серия: SN54AS21 (4)
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
59628780401CA, 5962 8780401CA
На английском языке: Datasheet Texas Instruments 5962-8780401CA
