Datasheet Texas Instruments UC2705N — Даташит
СерияUC2705
МодельUC2705N
Дополнительный высокоскоростной драйвер питания 8-PDIP от -40 до 85
High Speed Power Driver datasheet
PDF, 891 Кб, Версия: D, Файл опубликован: 8 мар 2012
Интегральные микросхемы Силовые чипы — драйверы затворов
UC2705N
398 ₽
UC2705N
467 ₽
ЭИК
UC2705N
Unitrode
1 906 ₽
LIXINC Electronics
UC2705N
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаUC2705N
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Channel Input LogicN/A
Fall Time40 нс
Input ThresholdTTL
Input VCC(Max)40 В
Input VCC(Min)5 В
Количество каналов1
Package GroupPDIP
Peak Output Current1.5 A
Power SwitchMOSFET,IGBT
Prop Delay100 нс
Rise Time40 нс
Special FeaturesN/A
  • U-118 New Driver ICs Optimize High-Speed Power MOSFET Switching Characteristics
    PDF, 573 Кб, Файл опубликован: 5 сен 1999
    The UC3705 family of power drivers is made with a high speed Schottky process to interface between low-level control functions and high-power switching devices particularly power MOSFETs. These devices are also an optimum choice for capacitive line drivers where up to 1.5 amps may be switched in either direction. With both inverting and non-inverting inputs available logic signals of either pola
  • U-137 Practical Considerations in High Performance MOSFET IGBT and MCT Gate
    PDF, 244 Кб, Файл опубликован: 5 сен 1999
    The switch-mode power supply industry's trend towards higher conversion frequencies is justified by the dramatic improvement in obtaining higher power densities. And as these frequencies are pushed towards and beyond one MHz the MOSFET transition periods can become a significant portion of the total switching period. Losses associated with the overlap of switch voltage and current not only degrad
Серия: UC2705 (4)
  • Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Low-side Driver
На английском языке: Datasheet Texas Instruments UC2705N
