Datasheet Texas Instruments CD54HCT393F3A — Даташит
Серия | CD54HCT393 |
Модель | CD54HCT393F3A |
Высокоскоростной КМОП-логический двойной 4-ступенчатый двоичный счетчик 14-CDIP от -55 до 125
CD54HC393, CD74HC393, CD54HCT393, CD74HCT393 datasheet
PDF, 718 Кб, Версия: E, Файл опубликован: 21 авг 2003
![]() 22 предложений от 20 поставщиков Counter/Divider Dual 4Bit Binary UP 14Pin CDIP Tube | |||
CD54HCT393F3A Texas Instruments | 2 459 ₽ | ||
CD54HCT393F/3A Texas Instruments | по запросу | ||
CD54HCT393F3AS2035 Harris | по запросу | ||
CD54HCT393F3A Texas Instruments | по запросу |
Pin | 14 | 14 |
Package Type | J | J |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | 5962-8989001CA | CD54HCT393F3A |
Width (мм) | 6.67 | 6.67 |
Length (мм) | 19.56 | 19.56 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
Bits | 4 |
F @ Nom Voltage(Max) | 25 Mhz |
Function | Counter |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 4/-4 мА |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | HCT |
Тип | Binary |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 78 нс |
RoHS | See ti.com |
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HCT393 (3)
- 5962-8989001CA CD54HCT393F CD54HCT393F3A
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
