Datasheet Texas Instruments REG103GA-5G4 — Даташит
СерияREG103
МодельREG103GA-5G4
500 мА, малошумящий регулятор с малым падением напряжения 6-SOT-223 от -40 до 85
DMOS 500mA Low-Dropout Regulator datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 22 сен 2005
Чип стабилизации напряжения, TEXAS INSTRUMENTS REG103GA-5G4 Fixed LDO Voltage Regulator, 2.1V to 15V, 160mV Dropout, 5Vout, 500mAout, SOT-223-5
T-electron
REG103GA-5G4
283 ₽
REG103GA-5G4
448 ₽
REG103GA-5G4
508 ₽
IC Home
REG103GA-5G4
Pin6
Package TypeDCQ
Industry STD TermSOT-223
Package QTY78
МаркировкаR103G50
Width (мм)3.5
Length (мм)6.5
Thickness (мм)1.6
Max Height (мм)1.8
Точность2 %
Fixed Output Options2.5,3,3.3,5 В
Iout(Max)0.5 A
Iq(Typ)1 мА
Noise33 uVrms
Output Capacitor TypeCap Free,Ceramic
PSRR @ 100KHz20 дБ
Package GroupSOT-223
Package Size: mm2:W x L6SOT-223: 46 mm2: 7.06 x 6.5(SOT-223) PKG
Regulated Outputs1
Special FeaturesEnable,Power Good
Thermal Resistance ОёJA150 В°C/W
Vdo(Typ)115 мВ
Vin(Max)15 В
Vin(Min)2.7 В
Vout(Max)5.5 В
Vout(Min)1.3 В
  • Evaluation Modules & Boards: TPS79328EVM
    TPS79328 Evaluation Module
  • Evaluation Modules & Boards: TPS76933EVM-127
    SOT23 LDO, 5 V to 1.0 V, 100mA output power supply
  • Evaluation Modules & Boards: DEM-SOT223LDO
    DEM-SOT223LDO Compatible with Most Positive Output LDOs in SOT223 (DCQ) Package
  • Evaluation Modules & Boards: TPS76901EVM-127
    SOT23 LDO, 5 V to 1.8 V, 100mA output power supply
  • Evaluation Modules & Boards: TPS79301EVM
    TPS79301 Evaluation Module
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
REG103GA5G4, REG103GA 5G4
На английском языке: Datasheet Texas Instruments REG103GA-5G4
