Источники питания Keen Side
Datasheet Texas Instruments UCC3818PWTR — Даташит
СерияUCC3818
МодельUCC3818PWTR
Предварительный регулятор коэффициента мощности BiCMOS 16-TSSOP от 0 до 70
UCC2817, UCC2818, UCC3817 and UCC3818 BiCMOS Power Factor Pregulator datasheet
PDF, 1.4 Мб, Версия: K, Файл опубликован: 1 окт 2016
15 предложений от 12 поставщиков
Микросхема Управление питанием, Power Factor Correction PREREGUL 0.15mA 115kHz 16Pin TSSOP T/R
UCC3818PWTR
85 ₽
T-electron
UCC3818PWTR
148 ₽
Элитан
UCC3818PWTR
296 ₽
UCC3818PWTR
332 ₽
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка3818PW
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)1.15 | 1ku
Control MethodCCM
Device TypeSingle-phase PFC
Operating Supply Current(mA)4
Operating Supply(Max)(V)18
Package GroupTSSOP
Peak Output Sink Current Gate Drive(A)1.2
Peak Output Source Current Gate Drive(A)-1.2
Practical Operating Frequency(Max)(MHz)0.25
Special Features750W Applications
Average Current Mode
Enable
OVP
Startup Current(mA)0.15
UVLO Thresholds On/Off(V)10.5/10
  • Evaluation Modules & Boards: UCC3817EVM
    UCC3817EVM BiCMOS Power Factor Preregulator EVM
  • PFC Family Differences UCC3817A/18A/19A and UCC3817/18/19
    PDF, 32 Кб, Файл опубликован: 18 авг 2003
    The UCC3817A/18A/19A family of PFC controllers (UCC3817A family) is pin for pin compatible with the UCC3817/18/19 family of devices (UCC3817 family). The output stage of UCC3817A family has been updated to allow use of a smaller external gate drive resistor values. For some power supply designs where an adequately high enough gate drive resistor can not be used, the UCC3817A family offers a more r
  • UCC3817 Current Sense Transformer Evaluation
    PDF, 49 Кб, Файл опубликован: 13 фев 2004
  • Synchronizing a PFC Controller from a Down Stream Controller Gate Drive
    PDF, 103 Кб, Файл опубликован: 3 ноя 2000
    Due to pending line harmonic requirements at higher power levels, power factor correction (PFC) is required in some ac-to-dc off-line power converter applications. This type of power converter can be designed with two cascaded power stages similar to the configuration in Figure 1. The first stage is a boost converter that converts the ac voltage to dc voltage with PFC. The output voltage of the bo
  • AC Requirements for Power Factor Correction Circuits
    PDF, 29 Кб, Файл опубликован: 28 мар 2002
    This technical brief identifies the recommended range of IAC for each of the devices within the UCC3854 family of PFC controllers.
  • Startup Current transient of the Leading Edge Triggered PFC Controllers
    PDF, 43 Кб, Файл опубликован: 30 июн 2004
  • Avoiding Audible Noise at Light Loads When Using Leading Edge Triggered PFC Con (Rev. C)
    PDF, 57 Кб, Версия: C, Файл опубликован: 13 апр 2011
    This application note applies to the TI average current mode, leading edge modulation PFC controllers. See Applicable Device Table for part numbers.
  • DN-66 UC3854A/B and UC3855A/B Provide Power Limiting with Sinusoidal Input (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 6 ноя 2001
  • Accurate PWM Duty Cycle Clamp
    PDF, 58 Кб, Файл опубликован: 25 янв 2002
    Power supply applications using current sense transformers require a duty cycle clamp on the pulse width modulator (PWM) to ensure transformer reset. Not all PWMs come with a duty cycle clamp presenting a problem for the power supply designer. This application note shows how to implement a duty cycle clamp by using a simple delay circuit.
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
На английском языке: Datasheet Texas Instruments UCC3818PWTR
