Datasheet Texas Instruments SN74LVC1G386DCKR — Даташит
СерияSN74LVC1G386
МодельSN74LVC1G386DCKR
Одиночный вентиль положительного исключающего ИЛИ с 3 входами 6-SC70 от -40 до 125
SN74LVC1G386 datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 24 дек 2012
45 предложений от 17 поставщиков
Интегральные микросхемы Логические микросхемы - Затворы и Инверторы
SN74LVC1G386DCKR
от 3.57 ₽
T-electron
SN74LVC1G386DCKR
7.16 ₽
SN74LVC1G386DCKR
от 14 ₽
SN74LVC1G386DCKR
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаC8R
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeXOR
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power
Sub-FamilyXOR Gate
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)12,5.5,5,4 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G386DCKR
