Клеммные колодки Keen Side
Datasheet Texas Instruments SN74CBTS3384DBLE — Даташит
СерияSN74CBTS3384
МодельSN74CBTS3384DBLE
10-битный переключатель шины на полевом транзисторе с ограничением на диоде Шоттки 24-SSOP от -40 до 85
SN74CBTS3384 datasheet
PDF, 874 Кб, Версия: M, Файл опубликован: 9 июл 2003
10Bit FET Bus Switch With Schottky Diode Clamping 24-SSOP -40℃ to 85℃
SN74CBTS3384DBLE
12 ₽
SN74CBTS3384DBLE
12 ₽
Зенер
Россия и страны ТС
SN74CBTS3384DBLE
34 ₽
ЭИК
SN74CBTS3384DBLE
36 ₽
Pin24
Package TypeDB
Industry STD TermSSOP
Width (мм)5.3
Length (мм)8.2
Thickness (мм)1.95
Max Height (мм)2
Additional FeaturesLow Power
Approx. Price (US$)0.27 | 1ku
Bandwidth(MHz)200
ConfigurationSPST
ICC(Max)(uA)3
Input/Ouput Voltage(Max)(V)5.5
Input/Output Continuous Current(Max)(mA)128
Number of Channels(#)10
Operating Temperature Range(C)-40 to 85
Package GroupSSOP
Package Size: mm2:W x L (PKG)24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP)
Ron(Max)(Ohms)7
Ron(Typ)(Ohms)5
VCC(Max)(V)5.5
VCC(Min)(V)4
RoHSНе совместим
  • SN74CBTS3384 Bus Switches Provide Fast Connection and Ensure Isolation (Rev. A)
    PDF, 46 Кб, Версия: A, Файл опубликован: 1 авг 1996
    Buses are the pathways for communication between the CPU, memory, and I/O ports in electronic systems. The SN74CBTS3384 bus switch provides a high-speed, low-power solution to bus connections while providing a reliable solution to bus isolation. This document describes the mechanics of MOSFET switches which can lead to false switching and disruption of the bus. The SN74CBTS3384 solution to theses
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
  • Semiconductors > Switches and Multiplexers > Signal Switches > Digital Switch
На английском языке: Datasheet Texas Instruments SN74CBTS3384DBLE
