Клеммные колодки Keen Side
Datasheet Texas Instruments ADS8201IRGER — Даташит
СерияADS8201
МодельADS8201IRGER
2,2–5,5 В, малое энергопотребление, 12 бит, 100 квыб./с, 8-канальный DAS с PGA и SPI™ 24-VQFN от -40 до 85
2.2V to 5.5V, Low-Power, 12-Bit, 100kSPS, 8-Ch Data Acq System with PGA and SPI datasheet
PDF, 771 Кб, Версия: B, Файл опубликован: 10 май 2010
Микросхема Преобразователь AD, 2.2V to 5.5V, Low-Power, 12Bit, 100KSPS, 8Channel DAS with PGA and SPITM 24-VQFN -40℃ to 85℃
ADS8201IRGER
204 ₽
ADS8201IRGER
568 ₽
Элитан
ADS8201IRGE
985 ₽
ЗУМ-СМД
ADS8201IRGER
Pin2424
Package TypeRGERGE
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка8201ADS
Width (мм)44
Length (мм)44
Thickness (мм).88.88
Pitch (мм).5.5
Max Height (мм)11
# Input Channels8
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.2 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.2 В
INL(Max)1.5 +/-LSB
Input Range(Max)5.5 В
Тип входаDifferential,Single-Ended
Integrated FeaturesOscillator,PGA
InterfaceSPI
Package GroupVQFN
Package Size: mm2:W x L24VQFN: 16 mm2: 4 x 4(VQFN) PKG
Power Consumption(Typ)1.32 mW
Reference ModeExt
Разрешение12 Bits
SINADN/A дБ
Sample Rate (max)100kSPS SPS
Sample Rate(Max)0.1 MSPS
THD(Typ)N/A дБ
  • Obtaining 17 Bits of Resolution using a 12-Bit A/D System on a Chip
    PDF, 337 Кб, Файл опубликован: 24 июн 2010
    Integrated data acquisition systems can provide many benefits over discrete component designs. Superior performance, power, and cost savings, along with shorter development times, are among these benefits. Features such as integrated programmable gain amplifiers and averaging can provide added resolution. This application note includes information on how to achieve 17 bits of effective resolution
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS8201 (4)
На английском языке: Datasheet Texas Instruments ADS8201IRGER
