Datasheet Texas Instruments TPS2421-1DDAR — Даташит
Серия | TPS2421-1 |
Модель | TPS2421-1DDAR |
20V, 5A, 33mО© eFuse with PG 8-SO PowerPAD -40 to 125
TPS2421-x 5-A, 20-V Integrated FET Hot Swap datasheet
PDF, 1.7 Мб, Версия: J, Файл опубликован: 18 окт 2016
![]() 26 предложений от 16 поставщиков Контролер нагрузки, 20V, 5A, 33m eFuse with PG 8-SO PowerPAD -40℃ to 125℃ | |||
TPS2421-1DDAR Texas Instruments | 86 ₽ | ||
TPS2421-1DDAR Texas Instruments | 105 ₽ | ||
TPS2421-1DDAR Texas Instruments | 219 ₽ | ||
TPS2421-1DDAR Texas Instruments | по запросу |
Pin | 8 |
Package Type | DDA |
Industry STD Term | HSOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2421-1 |
Width (мм) | 3.9 |
Length (мм) | 4.89 |
Thickness (мм) | 1.48 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.7 |
Mechanical Data | Скачать |
Channel(s) Controlled | 1 |
Current Limit Accuracy | В±14% at 5.5A |
Current Limit Function Enabled | Always |
Current Limit Type | Adjustable |
Current Limit(Max) | 5.5 A |
Current Limit(Min) | 1.8 A |
FET Protection | SOA,Thermal |
Fault Response | Latch Off |
Imax | 5.5 A |
Количество каналов | 1 |
ON_OFF Control Input | EN/ s |
Overcurrent Response | Current Limiting |
Overvoltage Response | N/A |
Package Group | SO PowerPAD |
Package Size: mm2:W x L | 8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG |
Rise Time(Typ) | 430 us |
Ron(Typ) | 33 mOhm |
Special Features | Fault Reporting,Power Good,Thermal Shutdown |
UL Recognition | Yes |
Vabsmax_cont | 25 В |
Vin(Max) | 20 В |
Vin(Min) | 3 В |
- Evaluation Modules & Boards: TPS2421-1EVM-02
TPS2421-1 Hot Swap Controller Evaluation Module
Серия: TPS2421-1 (2)
- TPS2421-1DDA TPS2421-1DDAR
- Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
TPS24211DDAR, TPS2421 1DDAR
