Datasheet Texas Instruments LM25575QMHX/NOPB — Даташит
СерияLM25575-Q1
МодельLM25575QMHX/NOPB
SIMPLE SWITCHERВ® 42V, 1.5A Step-Down Switching Regulator 16-HTSSOP -40 to 125
LM25575/LM25575Q SIMPLE SWITCHERВ® 42V, 1.5A Step-Down Switching Regulator (Rev. G)
PDF, 1.1 Мб, Версия: G, Файл опубликован: 3 апр 2013
17 предложений от 11 поставщиков
LM25575QMHX/NOPB
189 ₽
Akcel
LM25575QMHX/NOPB
от 243 ₽
LM25575QMHX/NOPB
774 ₽
LM25575QMHX/NOPB
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаQMHL25575
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Approx. Price (US$)2.10 | 1ku
Control ModeCurrent Mode
Duty Cycle(Max)(%)95
Iout(Max)(A)1.5
Iq(Typ)(mA)1
Operating Temperature Range(C)-40 to 125
Package GroupHTSSOP
RatingAutomotive
Regulated Outputs(#)1
Special FeaturesFrequency Synchronization
Switching Frequency(Max)(kHz)1000
Switching Frequency(Min)(kHz)50
ТипConverter
Vin(Max)(V)42
Vin(Min)(V)6
Vout(Max)(V)40
Vout(Min)(V)1.23
  • Evaluation Modules & Boards: LM25575EVAL
    Evaluation Board for LM25575, 42V, 1.5A Step-Down Switching Regulator
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • WEBENCHВ® Power Architect Project Report
    PDF, 206 Кб, Файл опубликован: 17 фев 2012
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Quick Start Guide for a 1.5 Amp Buck Regulator Using the LM5575 and LM25575 (Rev. B)
    PDF, 63 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note provides an easy to use process to help users design a 1.5 Amp buck regular usingthe LM5575 and LM25575 switching regulators.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
Серия: LM25575-Q1 (2)
На английском языке: Datasheet Texas Instruments LM25575QMHX/NOPB
