Datasheet Texas Instruments OPA177GSE4 — Даташит
Серия | OPA177 |
Модель | OPA177GSE4 |
Прецизионный операционный усилитель 8-SOIC
Precision Operational Amplifier datasheet
PDF, 296 Кб, Файл опубликован: 27 сен 2000
![]() 11 предложений от 11 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS OPA177GSE4 Operational Amplifier, Single, 1 Amplifier, 600kHz, 0.3V/µs, ± 3V to ± 18V, SOIC, 8Pins | |||
OPA177GSE4 Texas Instruments | 86 ₽ | ||
OPA177GSE4 Texas Instruments | 130 ₽ | ||
OPA177GSE4 Texas Instruments | 167 ₽ | ||
OPA177GSE4 Texas Instruments | 404 ₽ |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 75 | 75 |
Carrier | TUBE | TUBE |
Маркировка | 177GS | OPA |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | N/A |
Архитектура | FET |
CMRR(Min) | 115 дБ |
CMRR(Typ) | 140 дБ |
GBW(Typ) | 0.6 МГц |
Input Bias Current(Max) | 2000 pA |
Iq per channel(Max) | 2 мА |
Iq per channel(Typ) | 1.3 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 0.1 uV/C |
Output Current(Typ) | 22 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | Out |
Rating | Catalog |
Slew Rate(Typ) | 0.3 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 6 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 7.5 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.025 мВ |
- Diode-Based Temperature MeasurementPDF, 44 Кб, Файл опубликован: 27 сен 2000
Diodes are frequently used as temperature sensors in a wide variety of moderate-precision temperature measurement applications. The relatively high temperature coefficient of about -2mV/В°C is fairly linear. To make a temperature measurement system with a diode requires excitation, offsetting, and amplification. The circuitry can be quite simple. This Bulletin contains a collection of circuits - Boost Instrument Amp CMR With Common-Mode Driven SuppliesPDF, 175 Кб, Файл опубликован: 27 сен 2000
Ever-increasing demands are being placed on instrumentation amplifier (IA) performance. When standard IAs can not deliver the required performance, consider this enhanced version. Dramatic performance improvements can be achieved by operating the input amplifiers of a classical three-op-amp IA from common-mode driven sub-regulated power supplies. - Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA177 (10)
