Datasheet Texas Instruments SN74LVT245BPWRE4 — Даташит
СерияSN74LVT245B
МодельSN74LVT245BPWRE4
Приемопередатчики с восьмеричной шиной ABT, 3,3 В, с выходами с 3 состояниями 20-TSSOP от -40 до 85
SN74LVT245B datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 9 сен 2003
12 предложений от 11 поставщиков
Микросхема Логический контроллер, 3.3V ABT Octal Bus Transceivers With 3-State Outputs 20-TSSOP -40℃ to 85℃
SN74LVT245BPWRE4
22 ₽
Элитан
SN74LVT245BPWRE4
97 ₽
SN74LVT245BPWRE4
SN74LVT245BPWRE4
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаLX245B
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Bits8
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Package GroupTSSOP
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)3.5 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVT245BPWRE4
