Datasheet Texas Instruments UC2525BDWTRG4 — Даташит
СерияUC2525B
МодельUC2525BDWTRG4
Регулирующие широтно-импульсные модуляторы 16-SOIC от -40 до 85
Regulating Pulse Width Modulators datasheet
PDF, 1.6 Мб, Файл опубликован: 5 сен 1999
12 предложений от 11 поставщиков
Voltage Mode PWM Controller 400mA 400kHz 16Pin SOIC T/R
UC2525BDWTRG4
240 ₽
UC2525BDWTRG4
313 ₽
T-electron
UC2525BDWTRG4
315 ₽
UC2525BDWTRG4
Вебинар «Как выбрать идеальный силовой модуль: решения SUNCO для силовой электроники» (03.12.2024)
Pin16
Package TypeDW
Package QTY2000
МаркировкаUC2525BDW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Control MethodVoltage
Duty Cycle(Max)49 %
Frequency(Max)500 kHz
Frequency(Min)0.1 kHz
Gate Drive(Typ)0.5 A
Special FeaturesError Amplifier,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Buck,Flyback,Forward,Half-Bridge,Push-Pull
UVLO Thresholds On/Off7.0/6.5 В
Vin(Max)35 В
Vin(Min)8 В
  • DN-36 UC1525B/UC1527B Devices - Comparison Summary to UC1525A/27A Devices
    PDF, 19 Кб, Файл опубликован: 5 сен 1999
    The UC1525B and UC1527B are enhanced versions of the previous generation of UC1525A and UC1527A devices. They are pin-for-pin compatible and direct replacements for the A versions in almost all applications. The table in this design note compares the two sets of devices. Significant improvements have been made in the 5.1 V reference voltage and the output drivers as itemized in the table.
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UC2525B (2)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC2525BDWTRG4
