Datasheet Texas Instruments LMR14050SDDA — Даташит
СерияLMR14050
МодельLMR14050SDDA
40V, 5A SIMPLE SWITCHER, 2.2MHz Step-Down Regulator with 40ОјA IQ 8-SO PowerPAD -40 to 125
LMR14050 SIMPLE SWITCHERВ® 40 V 5 A, 2.2 MHz Step-Down Converter with 40 µA IQ datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 17 мар 2015
28 предложений от 11 поставщиков
LIXINC Electronics
LMR14050SDDA
от 184 ₽
LMR14050SDDA
211 ₽
T-electron
LMR14050SDDA
259 ₽
LMR14050SDDA
Package TypeDDA
Industry STD TermHSOIC
Package QTY75
МаркировкаDB5SP
Width (мм)3.9
Length (мм)4.89
Thickness (мм)1.48
Max Height (мм)1.7
Control ModeCurrent Mode
Duty Cycle(Max)98 %
Iout(Max)5 A
Iq(Typ)0.04 мА
Package GroupSO PowerPAD
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Pre-Bias Start-Up,Tracking,UVLO Adjustable
Switching Frequency(Max)2500 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)40 В
Vin(Min)4 В
Vout(Max)36 В
Vout(Min)1 В
  • Evaluation Modules & Boards: LMR14050SEVM
    LMR14050S Step-Down Converter Evaluation Module
  • How to Evaluate the Maximum Inductor in Internal Compensation PCM Buck Converter
    PDF, 2.3 Мб, Файл опубликован: 20 сен 2017
    With simple frequency compensation, Peak Current Mode (PCM) control is commonly used in integratedcircuits (IC) to improve the line and load transient performance. Slope compensation is implemented toprevent sub-harmonic oscillations at a duty cycle greater than 50%. Usually the inductor is considered asa current source in a simplified PCM buck converter model, which actually has a significa
  • SIMPLE SWITCHER Regulators Take Over Automotive Applications (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Power management applications, typically located on the front line of the automotive electronics system,can be subject to wide input operating voltage extremes resulting from load-dump and cold-crankingconditions. Careful selection of the power management electronics can provide added margin andprotection to the automotive electronics system. The simplest design is provided by a power manage
  • AN-2020 Thermal Design By Insight, Not Hindsight (Rev. C)
    PDF, 568 Кб, Версия: C, Файл опубликован: 23 апр 2013
    This application report provides an in-depth discussion of thermal design.
  • AN-1533 Overvoltage Protection Circuit for Automotive Load Dump (Rev. B)
    PDF, 83 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application report discusses an over voltage protection circuit for automotive load dump.
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
Серия: LMR14050 (2)
На английском языке: Datasheet Texas Instruments LMR14050SDDA
