Datasheet Texas Instruments LF398H — Даташит
СерияLF398-N
МодельLF398H
Монолитная схема выборки и хранения 8-TO-99 от 0 до 70
LF298, LFx98x Monolithic Sample-and-Hold Circuits datasheet
PDF, 2.9 Мб, Версия: B, Файл опубликован: 30 ноя 2015
37 предложений от 23 поставщиков
727GS
LF398H/NOPB
5.94 ₽
LF398H
85 ₽
LF398H
358 ₽
LF398H-N
Package TypeLMC
Industry STD TermTO-CAN
JEDEC CodeO-MBCY-W
Package QTY500
МаркировкаLF398H
Width (мм)9.08
Length (мм)9.08
Thickness (мм)4.4
Pitch (мм)2.54
Max Height (мм)5.72
RatingMilitary
RoHSTBD
  • Freq-to-Vltg Converter Uses Sample-and-Hold to Improve Response & Ripple
    PDF, 119 Кб, Файл опубликован: 3 окт 2002
  • AN-294 Special Sample and Hold Techniques
    PDF, 273 Кб, Файл опубликован: 10 май 2004
    Application Note 294 Special Sample and Hold Techniques
  • Specifications and Architectures of Sample-and-Hold Amplifiers
    PDF, 112 Кб, Файл опубликован: 3 май 2004
    Application Note 775 Specifications and Architectures of Sample-and-Hold Amplifiers
  • Applications of the LM3524 Pulse Width Modulator (Rev. B)
    PDF, 549 Кб, Версия: B, Файл опубликован: 23 апр 2013
    The LM3524 regulating pulse-width-modulator (PWM) is commonly used as the control element inswitching regulator power supplies. This is in keeping with its intended purpose. Engineers closelyassociate this part with switching power supplies. Nevertheless, the flexible combination of elements (seebox) within the LM3524 also allows it to be used in a number of other applications outside the po
  • AN-301 Signal Conditioning for Sophisticated Transducers (Rev. B)
    PDF, 1.2 Мб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses signal conditioning and applications information for a diverse group ofsophisticated and unusual transducers.
  • Data Acq Using ADC0816 & ADC0817 8-Bit ADC w/On-Chip 16 Chan Multiplexr
    PDF, 722 Кб, Файл опубликован: 10 май 2004
    Application Note 258 Data Acquisition Using the ADC0816 and ADC0817 8-Bit A/D Convert er with On-Chip 16 Channel Multiplexer
  • Using ADC0808/809 8-Bit uP Compble ADCs w/8-Chan Analog Multiplexr (Rev. B)
    PDF, 1.4 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application note discusses the use of the ADC0808/ADC0809 Data Acquisition Devices (DAD) withan 8-channel analog multiplexer.
  • AN-298 Isolation Techniques for Signal Conditioning (Rev. B)
    PDF, 685 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note provides information and examples of isolation techniques for signal conditioning.
  • Semiconductors > Amplifiers > Special Function Amplifiers > Sample & Hold Amplifiers
На английском языке: Datasheet Texas Instruments LF398H
