Datasheet Texas Instruments OPA2345UAG4 — Даташит
Серия | OPA2345 |
Модель | OPA2345UAG4 |
Маломощные операционные усилители с однополярным питанием и Rail-To-Rail MicroAmplifier™ Series 8-SOIC от -40 до 85
Low Power, Single-Supply, Rail-To-Rail Operational MicroAmplifier™ Series datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 27 авг 2008
![]() 10 предложений от 10 поставщиков Микросхема Буферный усилитель, Low Power, Single-Supply, ail-To- ail Operational Amplifiers MicroAmplifier(TM) Series 8-SOIC -40℃ to 85℃ | |||
OPA2345UAG4 Texas Instruments | 104 ₽ | ||
OPA2345UAG4 Texas Instruments | 116 ₽ | ||
OPA2345UAG4 Texas Instruments | по запросу | ||
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 75 | 75 |
Carrier | TUBE | TUBE |
Маркировка | 2345UA | OPA |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | Decompensated |
Архитектура | CMOS |
CMRR(Min) | 76 дБ |
CMRR(Typ) | 92 дБ |
GBW(Typ) | 3 МГц |
Input Bias Current(Max) | 1 pA |
Iq per channel(Max) | 0.25 мА |
Iq per channel(Typ) | 0.15 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 3 uV/C |
Output Current(Typ) | 15 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 2 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.5 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 30 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 1 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2345 (4)
- OPA2345EA/250 OPA2345UA OPA2345UA/2K5 OPA2345UAG4
