Клеммные колодки Keen Side
Datasheet Texas Instruments SN74LVC14ARGYR — Даташит
СерияSN74LVC14A
МодельSN74LVC14ARGYR
Инвертор с шестигранным триггером Шмитта 14-VQFN от -40 до 125
SNx4LVC14A Hex Schmitt-Trigger Inverters datasheet
PDF, 1.4 Мб, Версия: AA, Файл опубликован: 30 июн 2015
37 предложений от 17 поставщиков
Микросхема Логический чип, TEXAS INSTRUMENTS SN74LVC14ARGYR Inverter, Schmitt Trigger, 74LVC14, 1Input, 24mA, 1.65V to 3.6V, VQFN-14
SN74LVC14ARGYR
от 21 ₽
SN74LVC14ARGYR
41 ₽
SN74LVC14ARGYR
60 ₽
Контест
SN74LVC14ARGYR
Pin14
Package TypeRGY
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаLC14A
Width (мм)3.5
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Bits6
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupVQFN
Package Size: mm2:W x L14VQFN: 12 mm2: 3.5 x 3.5(VQFN) PKG
Schmitt TriggerYes
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)2 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)11,7.8,7.5,6.4 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74LVC14ARGYR
