Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet Texas Instruments SN74LVTH574DBR — Даташит
СерияSN74LVTH574
МодельSN74LVTH574DBR
Восьмеричные триггеры D-типа ABT, 3,3 В, с триггером по фронту и выходами с 3 состояниями 20-SSOP от -40 до 85
SN54LVTH574, SN74LVTH574 datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 15 сен 2003
29 предложений от 16 поставщиков
Микросхема Бистабильный мультивибратор, 3.3V ABT Octal Edge-Triggered D-Type Flip-Flops With 3-State Outputs 20-SSOP -40℃ to 85℃
SN74LVTH574DBR
11 ₽
SN74LVTH574DBR
20 ₽
SN74LVTH574DBR
34 ₽
SN74LVTH574DBR
35 ₽
Pin20
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаLXH574
Width (мм)5.3
Length (мм)7.2
Thickness (мм)1.95
Max Height (мм)2
3-State OutputYes
Bits8
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Output Drive (IOL/IOH)(Max)64/-32 мА
Package GroupSSOP
Package Size: mm2:W x L20SSOP: 56 mm2: 7.8 x 7.2(SSOP) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.5 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Flip-Flop
На английском языке: Datasheet Texas Instruments SN74LVTH574DBR
