Datasheet Texas Instruments V62/06669-01XE — Даташит
Серия | ADS5440-EP |
Модель | V62/06669-01XE |
13-разрядный аналого-цифровой преобразователь (АЦП) с быстродействием 210 MSPS — усовершенствованный продукт 80-HTQFP от -55 до 125
5 предложений от 5 поставщиков Микросхема Преобразователь AD, Single Channel Single ADC Pipelined 210MSPS 13Bit LVDS 80Pin HTQFP EP Tray | |||
V62/06669-01XE Texas Instruments | 8 961 ₽ | ||
V62/06669-01XE | по запросу | ||
V62/06669-01XE Texas Instruments | по запросу |
Pin | 80 |
Package Type | PFP |
Industry STD Term | HTQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 96 |
Carrier | JEDEC TRAY (10+1) |
Маркировка | ADS5440M-EP |
Width (мм) | 12 |
Length (мм) | 12 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Analog Voltage AVDD(Max) | 5.25 В |
Analog Voltage AVDD(Min) | 4.75 В |
Архитектура | Pipeline |
Digital Supply(Max) | 3.6 В |
Digital Supply(Min) | 3 В |
ENOB | 11.4 Bits |
INL(Max) | 2.2 +/-LSB |
INL(Typ) | 0.9 +/-LSB |
Interface | Parallel LVDS |
Package Group | HTQFP |
Package Size: mm2:W x L | 80HTQFP: 196 mm2: 14 x 14(HTQFP) PKG |
Power Consumption(Typ) | 2250 mW |
Rating | HiRel Enhanced Product |
Reference Mode | Int |
Разрешение | 13 Bits |
SFDR | 80 дБ |
SNR | 69 дБ |
Sample Rate (max) | 210MSPS SPS |
- Evaluation Modules & Boards: TSW2200EVM
TSW2200 Low-Cost Portable Power Supply Evaluation Module
- Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir - CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital ConvertersPDF, 424 Кб, Файл опубликован: 8 июн 2008
Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers - Phase Noise Performance and Jitter Cleaning Ability of CDCE72010PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig - High-Speed Analog-to-Digital Converter BasicsPDF, 1.1 Мб, Файл опубликован: 11 янв 2012
The goal of this document is to introduce a wide range of theories and topics that are relevant tohigh-speed analog-to-digital converters (ADC). This document provides details on sampling theorydata-sheet specifications ADC selection criteria and evaluation methods clock jitter and other commonsystem-level concerns. In addition some end-users will want to extend the performance capabil - Smart Selection of ADC/DAC Enables Better Design of Software-Defined RadioPDF, 376 Кб, Файл опубликован: 28 апр 2009
This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
Серия: ADS5440-EP (2)
- ADS5440MPFPEP V62/06669-01XE
- Semiconductors > Space & High Reliability > Data Converter > Analog to Digital Converters
V62/0666901XE, V62/06669 01XE
