Datasheet Texas Instruments SN74LVT32244GKER — Даташит
СерияSN74LVT32244
МодельSN74LVT32244GKER
3,3 В ABT, 32-битный буфер/драйвер с выходами с 3 состояниями 96-LFBGA от -40 до 85
SN74LVT32244 datasheet
PDF, 779 Кб, Версия: C, Файл опубликован: 1 ноя 2006
16 предложений от 15 поставщиков
Микросхема Логический чип, Buffer/Line Driver 32CH Non-Inverting 3-ST BiCMOS 96Pin BGA MICROSTAR T/R
ЭИК
SN74LVT32244GKER
727 ₽
SN74LVT32244GKER
Контест
SN74LVT32244GKER
SN74LVT32244GKER
Pin96
Package TypeGKE
Industry STD TermBGA MICROSTAR
JEDEC CodeR-PBGA-N
Package QTY1000
МаркировкаVJ244
Width (мм)5.5
Length (мм)13.5
Thickness (мм).9
Pitch (мм).8
Max Height (мм)1.4
Bits32
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Package GroupLFBGA
Package Size: mm2:W x L96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)3.2 нс
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT32244 (2)
На английском языке: Datasheet Texas Instruments SN74LVT32244GKER
