Datasheet Texas Instruments ADS1212U/1KG4 — Даташит
Серия | ADS1212 |
Модель | ADS1212U/1KG4 |
22-битный аналого-цифровой преобразователь 18-SOP от -40 до 85
ADS1212, ADS1213: 22-Bit Analog-to-Digital Converter datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 18 фев 2004
Купить ADS1212U/1KG4 на РадиоЛоцман.Цены — от 994 до 1 643 ₽ 10 предложений от 10 поставщиков ADC Single Delta-Sigma 6.25KSPS 22Bit Serial 18Pin SOP T/R | |||
ADS1212U/1KG4 Texas Instruments | 994 ₽ | ||
ADS1212U/1KG4 Texas Instruments | 1 632 ₽ | ||
ADS1212U/1KG4 | по запросу | ||
ADS1212U/1KG4 Texas Instruments | по запросу |
Pin | 18 | 18 |
Package Type | DTC | DTC |
Industry STD Term | SOP | SOP |
Package QTY | 1000 | 1000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | ADS | 1212U |
Width (мм) | 7.5 | 7.5 |
Length (мм) | 11.55 | 11.55 |
Thickness (мм) | 2.3 | 2.3 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 2.65 | 2.65 |
- Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
- AB-174: Getting the Full Potential from your ADC (Rev. A)PDF, 72 Кб, Версия: A, Файл опубликован: 28 июн 2002
Many of today?s high-resolution ADCs (Analog-to-Digital Converters) are operating from a single supply and use fully differential inputs. This can be a problem for single-ended signals that are bipolar relative to common. This article illustrates circuit configurations that preserve the full-scale input range by using modern features, such as Programmable Gain Amplifiers (PGAs) and internal voltag - A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Programming Tricks for Higher Conversion Speeds Utilizing Delta Sigma ConvertersPDF, 105 Кб, Файл опубликован: 27 сен 2000
Delta-Sigma Analog-to-Digital Converters are well known for their innate ability to resolve an analog input signal to very small LSB voltage ranges. The primarily applications for this type of product is in the Industrial Process Control market such as direct transducer interface for pressure, temperature, flow, weigh scales and force measurement systems. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
- Calibration Routines and Register Value Generation for the ADS121x SeriesPDF, 298 Кб, Файл опубликован: 19 июн 2003
In order to achieve the best possible performance, offset and gain can be often be calibrated in high-resolution analog-to-digital converters (ADCs). Changes in temperature, PGA gain, power supply voltage, or most importantly, decimation ratio can influence the accuracy of measurement. This application note explains how the calibration routines work and how to generate values for the full-scale re - Inputs Currents for High-Resolution ADCsPDF, 127 Кб, Файл опубликован: 6 мар 2003
- Coding Schemes Used with Data Converters (Rev. A)PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
Серия: ADS1212 (4)
- ADS1212U ADS1212U/1K ADS1212U/1KG4 ADS1212UG4
