Datasheet Texas Instruments CD74ACT14M96G4 — Даташит
Серия | CD74ACT14 |
Модель | CD74ACT14M96G4 |
Инверторы с шестигранным триггером Шмитта 14-SOIC от -55 до 125
![]() 10 предложений от 10 поставщиков Микросхема Триггер Шмитта, TEXAS INSTRUMENTS CD74ACT14M96G4 Inverter, Schmitt Trigger, 74ACT14, 1Input, 24mA, 4.5V to 5.5V, SOIC-14 | |||
CD74ACT14M96G4 Texas Instruments | 5.83 ₽ | ||
CD74ACT14M96G4 Texas Instruments | 15 ₽ | ||
CD74ACT14M96G4 | по запросу | ||
CD74ACT14M96G4 Texas Instruments | по запросу |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | ACT14M |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 6 |
F @ Nom Voltage(Max) | 90 Mhz |
ICC @ Nom Voltage(Max) | 0.04 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | Yes |
Technology Family | ACT |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 13.2 нс |
- Understanding Schmitt TriggersPDF, 80 Кб, Файл опубликован: 21 сен 2011
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD74ACT14 (5)
- CD74ACT14E CD74ACT14M CD74ACT14M96 CD74ACT14M96G4 CD74ACT14MG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
