Источники питания Keen Side
Datasheet Texas Instruments SN74ALVTH32244KR — Даташит
СерияSN74ALVTH32244
МодельSN74ALVTH32244KR
32-битные буферы/драйверы 2,5 В/3,3 В с выходами с 3 состояниями 96-LFBGA от -40 до 85
2.5-V/3.3-V 32-Bit Buffers/Drivers With 3-State Outputs datasheet
PDF, 889 Кб, Файл опубликован: 3 сен 1999
Микросхема Логический чип, Buffer/Line Driver 32CH Non-Inverting 3-ST BiCMOS 96Pin BGA MICROSTAR T/R
SN74ALVTH32244KR
67 ₽
T-electron
SN74ALVTH32244KR
122 ₽
SN74ALVTH32244KR
462 ₽
SN74ALVTH32244KR
Pin96
Package TypeGKE
Industry STD TermBGA MICROSTAR
JEDEC CodeR-PBGA-N
Package QTY1000
МаркировкаVL244
Width (мм)5.5
Length (мм)13.5
Thickness (мм).9
Pitch (мм).8
Max Height (мм)1.4
RoHSSee ti.com
  • Advanced Low-Voltage Technology
    PDF, 59 Кб, Файл опубликован: 27 июл 1999
    ALVT, the advanced low-voltage logic family, offers high-performance BiCMOS devices that are functional at 3.3-V and 2.5-V V sub CC and have low propagation delay, low static-power consumption, and 64 mA current drive. Other features include 5-V tolerance; auto3-state; bus hold; partial power down, hot insertion, and live insertion; and excellent simultaneous-switching and output-skew performance.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
Серия: SN74ALVTH32244 (2)
На английском языке: Datasheet Texas Instruments SN74ALVTH32244KR
