Datasheet Texas Instruments UAF42AUE4 — Даташит
СерияUAF42
МодельUAF42AUE4
Универсальный активный фильтр 16-SOIC от -25 до 85
Universal Active Filter   datasheet
PDF, 333 Кб, Версия: B, Файл опубликован: 24 окт 2010
15 предложений от 10 поставщиков
TEXAS INSTRUMENTS UAF42AUE4 Analogue Filter, Universal, 2nd, 3, 6 V, 18 V, SOIC
LIXINC Electronics
UAF42AUE4
от 198 ₽
UAF42AUE4
749 ₽
Akcel
UAF42AUE4
от 1 263 ₽
UAF42AUE4
1 411 ₽
Pin16
Package TypeDW
Package QTY40
МаркировкаUAF42AU
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Рабочий диапазон температурот -25 до 85 C
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Vs(Max)36 В
Vs(Min)12 В
  • Build a 3-Phase Sine Wave Generator with the UAF42
    PDF, 33 Кб, Файл опубликован: 4 окт 2000
    A three phase sine wave oscillator can be built using one UAF42 state variable filter along with some resistors and diodes. Three output nodes are available; highpass out, bandpass out and lowpass out. The signal at the bandpass and lowpass out nodes are 90В° and 180В° out of phase, respectively, with the highpass out node. An on-chip auxiliary op amp is available for use as a buffer or gain
  • Design a 60Hz Notch Filter with the UAF42
    PDF, 71 Кб, Файл опубликован: 4 окт 2000
    The UAF42 is a monolithic, time-continuous, 2nd-order active filter building block for complex and simple filter designs. It uses the classical state-variable analog architecture with a summing amplifier plus two integrators. This topology offers low sensitivity of filter design parameters fo (natural frequency) and Q to external component variations along with simultaneous high-pass, l
  • Simple Filter Turns Square Waves into Sine Waves
    PDF, 61 Кб, Файл опубликован: 27 сен 2000
    Many signals are digitally generated or transmitted as square waves. It is often desirable to convert these signals into sine waves. For example, the 350Hz, 440Hz, 480Hz, and 620Hz telephone supervisory tones transmitted over fiber-optics may appear at curb-side as square waves. To be used in telephone equipment it is desirable to convert the square waves into low-distortion sine waves. This can b
  • Filter Design Program For The UAF42 Universal Active Filter
    PDF, 540 Кб, Файл опубликован: 27 сен 2000
    Although active filters are vital in modern electronics, their design and verification can be tedious and time consuming. To aid in the design of active filters, Burr-Brown provides a series of FilterProВ™ computer-aided design programs. Using the FILTER42 program and the UAF42 it is easy to design and implement all kinds of active filters. The UAF42 is a monolithic IC which contains the op am
  • Digitally Programmable, Time-Continuous Active Filter
    PDF, 32 Кб, Файл опубликован: 27 сен 2000
    Programmable active filters have increased in popularity over the past decade. With the advent of switched capacitor topologies, filter parameters such as the natural frequency and filter Q can be changed simply by varying the clock frequency. But switched capacitor filters are sampled data systems and are subject to anomalies such as clock feedthrough noise and aliasing errors.
Серия: UAF42 (5)
  • Semiconductors > Amplifiers > Special Function Amplifiers > Frequency Converters
На английском языке: Datasheet Texas Instruments UAF42AUE4
