Datasheet Texas Instruments ADS7888SDBVTG4 — Даташит
СерияADS7888
МодельADS7888SDBVTG4
2,35–5,25 В, 8 бит, 1,25 MSPS, последовательный АЦП 6-SOT-23 от -40 до 125
ADS788x 10-Bit, 8-Bit, 1.25-MSPS, Micro-Power, Miniature SAR Analog-to-Digital Converters datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 24 авг 2016
Аналого-цифровые преобразователи (АЦП) 2.35V-5.25V 8 Bit 1.25MSPS Serial
ADS7888SDBVTG4
LifeElectronics
ADS7888SDBVTG4
HXD Co.
ADS7888SDBVTG4
Pin6
Package TypeDBV
Industry STD TermSOT-23
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
# Input Channels1
Analog Voltage AVDD(Max)(V)5.25
Analog Voltage AVDD(Min)(V)2.35
Approx. Price (US$)0.85 | 1ku
АрхитектураSAR
Digital Supply(Max)(V)5.25
Digital Supply(Min)(V)2.35
INL(Max)(+/-LSB)0.3
Input Range(Max)(V)5.25
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceSPI
Multi-Channel ConfigurationN/A
Operating Temperature Range(C)-40 to 125
Package GroupSOT-23
Package Size: mm2:W x L (PKG)6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
Power Consumption(Typ)(mW)3.8
Reference ModeSupply
Resolution(Bits)8
SINAD(dB)49.5
Sample Rate (max)(SPS)1.25MSPS
THD(Typ)(dB)-67.5
RoHSНе совместим
  • Evaluation Modules & Boards: ADS7888EVM
    ADS7888EVM Evaluation Module
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS7888SDBVTG4
