Datasheet Texas Instruments SN74LVC125ADRE4 — Даташит
Серия | SN74LVC125A |
Модель | SN74LVC125ADRE4 |
Четверной буферный вентиль шины с выходами с 3 состояниями, 14-SOIC, от -40 до 125
SN74LVC125A Quadruple Bus Buffer Gate With 3-State Outputs datasheet
PDF, 1.1 Мб, Версия: Q, Файл опубликован: 25 янв 2015
![]() 12 предложений от 11 поставщиков Микросхема Логический контроллер, Buffer/Line Driver 4CH Non-Inverting 3-ST CMOS 14Pin SOIC T/R | |||
SN74LVC125ADRE4 Texas Instruments | 7.32 ₽ | ||
SN74LVC125ADRE4 Texas Instruments | 8.24 ₽ | ||
SN74LVC125ADRE4 Texas Instruments | 11 ₽ | ||
SN74LVC125ADRE4 Texas Instruments | по запросу |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | LVC125A |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.04 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 11.8,5.8,5.3,4.6 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC125A (27)
- SN74LVC125AD SN74LVC125ADBLE SN74LVC125ADBR SN74LVC125ADBRG4 SN74LVC125ADE4 SN74LVC125ADG4 SN74LVC125ADR SN74LVC125ADRE4 SN74LVC125ADRG3 SN74LVC125ADRG4 SN74LVC125ADT SN74LVC125ADTG4 SN74LVC125ANSR SN74LVC125ANSRE4 SN74LVC125APW SN74LVC125APWE4 SN74LVC125APWG4 SN74LVC125APWLE SN74LVC125APWR SN74LVC125APWRE4 SN74LVC125APWRG3 SN74LVC125APWRG4 SN74LVC125APWT SN74LVC125APWTE4 SN74LVC125APWTG4 SN74LVC125ARGYR SN74LVC125ARGYRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
