Datasheet Texas Instruments LM86CIM/NOPB — Даташит
Серия | LM86 |
Модель | LM86CIM/NOPB |
В±0.75В°C Remote and Local Temperature Sensor with SMBus Interface 8-SOIC 0 to 125
0.75C Accurate, Remote Diode & Local Digital Temp Sensor w/Two-Wire Interface datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 22 мар 2013
Купить LM86CIM/NOPB на РадиоЛоцман.Цены — от 147 до 592 ₽ 15 предложений от 15 поставщиков Датчик температуры (ИС), Цифровой, ± 1°C, -55 °C, 125 °C, SOIC, 8 вывод(-ов) | |||
LM86CIM/NOPB Texas Instruments | 147 ₽ | ||
LM86CIM/NOPB National Semiconductor | 159 ₽ | ||
LM86CIM/NOPB National Semiconductor | 471 ₽ | ||
LM86CIM/NOPB Texas Instruments | 592 ₽ |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 95 | 95 |
Carrier | TUBE | TUBE |
Маркировка | CIM | LM86 |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Interface | I2C,SMBus |
Local Sensor Accuracy(Max) | 3 +/- C |
Рабочий диапазон температур | от 0 до 125 C |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rating | Catalog |
Remote Channel | 1 |
Remote Diode Temp Range for Listed Accuracy | 80 C |
Remote Sensor Accuracy(Max) | 0.75 +/- C |
Remote Sensor Correction | Offset Correction Register |
Remote Temp Resolution(Max) | 11 bits |
Special Features | Programmable Alert,Programmable conversion rate,Shutdown |
Supply Current(Typ) | 800 uA |
Supply Voltage(Max) | 3.6 В |
Supply Voltage(Min) | 3 В |
Temp Resolution(Max) | 8 bits |
Серия: LM86 (7)
- LM86CIM LM86CIM/NOPB LM86CIMM LM86CIMM/NOPB LM86CIMMX/NOPB LM86CIMX LM86CIMX/NOPB
- Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
