Datasheet Texas Instruments OPA861IDBVTG4 — Даташит
Серия | OPA861 |
Модель | OPA861IDBVTG4 |
Широкополосный операционный усилитель крутизны 6-SOT-23 от -40 до 85
Wide Bandwidth Operational Transconductance Amplifier (OTA) datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 14 май 2013
![]() 12 предложений от 12 поставщиков Микросхема Буферный усилитель, SP Amp Transconductance Amplifier Single ±6.3V/12.6V 6Pin SOT-23 T/R | |||
OPA861IDBVTG4 Texas Instruments | 96 ₽ | ||
OPA861IDBVTG4 Texas Instruments | 145 ₽ | ||
OPA861IDBVTG4 Texas Instruments | 153 ₽ | ||
OPA861IDBVTG4 | по запросу |
Pin | 6 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | NSR |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
Acl, min spec gain | 1 V/V |
BW @ Acl | 80 МГц |
GBW(Typ) | 400 МГц |
IIB(Max) | 1000 нА |
Iq per channel(Max) | 5.4 мА |
Количество каналов | 1 |
Output Current(Typ) | 15 мА |
Package Group | SOT-23 |
Package Size: mm2:W x L | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Slew Rate(Typ) | 900 V/us |
Vn at Flatband(Typ) | 2.4 нВ/rtГц |
Vos(Max) | 12 мВ |
Vs(Max) | 12.6 В |
Vs(Min) | 4 В |
- Evaluation Modules & Boards: DEM-OTA-SO-1A
Unpopulated PCB Compatible w/Wide Bandwidth Transconductance Op Amps in 8-lead SOIC (D) Pkg
- Demystifying the Operational Transconductance Amplifier (Rev. A)PDF, 259 Кб, Версия: A, Файл опубликован: 16 апр 2013
Operational transconductance amplifiers (OTAs) are often among the least understood analog components. However, these devices serve a very useful function that is being implemented on a regular basis in many integrated circuits as an element for more advanced purposes; the current feedback amplifier is among the most prominent example. The purpose of this application report is to show how this bui - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: OPA861 (8)
- OPA861ID OPA861IDBVR OPA861IDBVRG4 OPA861IDBVT OPA861IDBVTG4 OPA861IDG4 OPA861IDR OPA861IDRG4
- Semiconductors > Amplifiers > Special Function Amplifiers > Transconductance Amplifiers
