Datasheet Texas Instruments UC2852DTR — Даташит
Серия | UC2852 |
Модель | UC2852DTR |
Предварительный регулятор высокого коэффициента мощности 8-SOIC от -40 до 85
High Power-Factor Preregulator datasheet
PDF, 400 Кб, Файл опубликован: 5 сен 1999
Купить UC2852DTR на РадиоЛоцман.Цены — от 54 до 732 ₽ 20 предложений от 15 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Коррекция коэффициента мощности | |||
UC2852DTR Texas Instruments | от 54 ₽ | ||
UC2852DTR Texas Instruments | 177 ₽ | ||
UC2852DTR Texas Instruments | 732 ₽ | ||
UC2852DTR Texas Instruments | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | UC2852D |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Control Method | TM |
Device Type | Single-phase PFC |
Operating Supply Current | 6 мА |
Operating Supply(Max) | 30 В |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Peak Output Sink Current Gate Drive | 1 A |
Peak Output Source Current Gate Drive | -1 A |
Practical Operating Frequency(Max) | 0.2 МГц |
Rating | Catalog |
Special Features | < 150W Applications,Transition Mode Control |
Startup Current | 0.4 мА |
UVLO Thresholds On/Off | 16.3/11.5 В |
- U-132 Power Factor Correction Using UC3852 Controlled On-Time Zero CurrentPDF, 323 Кб, Файл опубликован: 5 сен 1999
The UC3852 provides a low-cost solution to active power-factor correction (PFC) for systems that would otherwise draw high peak current pulses from AC power lines. This circuit implements zero-current switched boost conversion, producing sinusoidal input currents with a minimum of external components, while keeping peak current substantially below that of fully-discontinuous converters. The contro
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
