Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet Texas Instruments 5962-9758701QFA — Даташит
СерияSN54F283
Модель5962-9758701QFA
4-битные полные двоичные сумматоры с быстрым переносом 16-CFP от -55 до 125
4-Bit Binary Full Adders With Fast Carry datasheet
PDF, 408 Кб, Версия: A, Файл опубликован: 1 окт 1993
HXD Co.
5962-9758701QFA
Pin16
Package TypeW
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Width (мм)6.73
Length (мм)10.3
Thickness (мм)1.65
Max Height (мм)2.03
Bits(#)4
F @ Nom Voltage(Max)(Mhz)70
FunctionArithmetic
ICC @ Nom Voltage(Max)(mA)55
Operating Temperature Range(C)-55 to 125
Output Drive (IOL/IOH)(Max)(mA)20/-1
Package GroupCFP
Package Size: mm2:W x L (PKG)See datasheet (CFP)
RatingMilitary
Technology FamilyF
ТипBinary
VCC(Max)(V)5.5
VCC(Min)(V)4.5
tpd @ Nom Voltage(Max)(ns)10.5
RoHSНе совместим
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Introduction to Logic
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
59629758701QFA, 5962 9758701QFA
На английском языке: Datasheet Texas Instruments 5962-9758701QFA
