Datasheet Texas Instruments PCA9515APWRG4 — Даташит
Серия | PCA9515A |
Модель | PCA9515APWRG4 |
Двойная двунаправленная шина I2C и повторитель SMBus 8-TSSOP от -40 до 85
PCA9515A Dual Bidirectional I2C Bus and SMBus Repeater datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 12 июн 2014
![]() 9 предложений от 9 поставщиков Чип интерфейса, I²C Logic Repeater 2.5V/3.3V 8Pin TSSOP T/R | |||
PCA9515APWRG4 Texas Instruments | 51 ₽ | ||
PCA9515APWRG4 Texas Instruments | 82 ₽ | ||
PCA9515APWRG4 Texas Instruments | 103 ₽ | ||
PCA9515APWRG4 Texas Instruments | по запросу |
Pin | 8 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | PD515A |
Width (мм) | 4.4 |
Length (мм) | 3 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Channel Width | 2 |
Master Side I2C Bus Capacitance Supported | 400 пФ |
Max Frequency | 400 kHz |
Количество выходов | 2 |
Package Group | TSSOP |
Slave Side I2C Bus Capacitance Supported | 400 пФ |
Special Features | Open-Drain I/O Type |
VCC(Max) | 3.6 В |
VCC(Min) | 2.3 В |
fSCLK(Max) | 0.4 МГц |
- Troubleshooting I2C Bus ProtocolPDF, 184 Кб, Файл опубликован: 19 окт 2009
When using the I2Cв„ў bus protocol, the designer must ensure that the hardware complies with the I2C standard. This application report describes the I2C protocol and provides guidelines on debugging a missing acknowledgment, selecting the pullup resistors, or meeting the maximum capacitance load of an I2C bus. A conflict occurs if devices sharing the I2C bus have the same slave address. This - Programming Fun Lights With TI's TCA6507PDF, 109 Кб, Файл опубликован: 30 ноя 2007
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: PCA9515A (14)
- Semiconductors > Interface > I2C > I2C Level Shifters, Buffers, and Hubs
