Datasheet Texas Instruments TLV2465CD — Даташит
Серия | TLV2465 |
Модель | TLV2465CD |
Четырехканальный операционный усилитель ввода/вывода малой мощности с функцией отключения 16-SOIC от 0 до 70
Rail-to-Rail Input/Output Operational Amplifiers w/ Shutdown datasheet
PDF, 2.7 Мб, Версия: J, Файл опубликован: 29 фев 2004
![]() 14 предложений от 13 поставщиков Микросхема Буферный усилитель, Op Amp Quad GP R-R I/O ±3V/6V 16Pin SOIC Tube | |||
TLV2465CD Texas Instruments | 78 ₽ | ||
TLV2465CD Texas Instruments | 116 ₽ | ||
TLV2465CD Texas Instruments | 122 ₽ | ||
TLV2465CD Texas Instruments | 518 ₽ |
Pin | 16 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 40 |
Carrier | TUBE |
Маркировка | TLV2465C |
Width (мм) | 3.91 |
Length (мм) | 9.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Shutdown |
Архитектура | Bipolar |
CMRR(Min) | 71 дБ |
CMRR(Typ) | 85 дБ |
GBW(Typ) | 6.4 МГц |
Input Bias Current(Max) | 14000 pA |
Iq per channel(Max) | 0.65 мА |
Iq per channel(Typ) | 0.55 мА |
Количество каналов | 4 |
Offset Drift(Typ) | 2 uV/C |
Рабочий диапазон температур | от -40 до 125,0 до 70 C |
Output Current(Typ) | 80 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 1.6 V/us |
Total Supply Voltage(Max) | 6 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 11 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 2 мВ |
- Using the TLV246x as a Multiplexer with Gain in a Data Acquisition SystemPDF, 62 Кб, Файл опубликован: 14 дек 1998
Using the TLV246x as a multiplexer lends itself to certain applications where system signals are only measured at power up, or are measured infrequently or periodically at slow sampling rates during operation. This application report describes the circuit and discusses measurement of key parameters. - TLV2461/62/63/64/65 EMI Immunity Performance (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 14 ноя 2012
- Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2465 (10)
