Datasheet Texas Instruments SN74AUC2G08DCTRG4 — Даташит
СерияSN74AUC2G08
МодельSN74AUC2G08DCTRG4
ДВОЙНОЙ 2-ВХОДНОЙ ПОЛОЖИТЕЛЬНЫЙ И ЗАТВОРНЫЙ 8-SM8 от -40 до 85
SN74AUC2G08 datasheet
PDF, 922 Кб, Версия: C, Файл опубликован: 12 янв 2007
Микросхема Логический чип, AND Gate 2Element 2IN CMOS 8Pin SSOP T/R
SN74AUC2G08DCTRG4
13 ₽
SN74AUC2G08DCTRG4
16 ₽
SN74AUC2G08DCTRG4
22 ₽
SN74AUC2G08DCTRG4
Pin888
Package TypeDCTDCTDCT
Industry STD TermSSOPSSOPSSOP
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаRU08Z
Width (мм)2.82.82.8
Length (мм)2.952.952.95
Thickness (мм)1.291.291.29
Pitch (мм).65.65.65
Max Height (мм)1.31.31.3
3-State OutputNo
Bits2
F @ Nom Voltage(Max)250 Mhz
Gate TypeAND
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSM8
Package Size: mm2:W x L8SM8: 12 mm2: 4 x 2.95(SM8) PKG
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyAND Gate
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)9.2,3,1.9,1.5,1 нс
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC2G08DCTRG4
