Datasheet Texas Instruments CD74HC132M96E4 — Даташит
Серия | CD74HC132 |
Модель | CD74HC132M96E4 |
Высокоскоростные КМОП-логики с 2 входами, управляемые Шмиттом вентили NAND, 14-SOIC, от -55 до 125
CD54HC132, CD74HC132, CD54HCT132, CD74HCT132 datasheet
PDF, 718 Кб, Версия: E, Файл опубликован: 19 мар 2004
![]() 9 предложений от 9 поставщиков Микросхема Логический чип, NAND Gate 4Element 2IN CMOS 14Pin SOIC T/R | |||
CD74HC132M96E4 Texas Instruments | 6.06 ₽ | ||
CD74HC132M96E4 Texas Instruments | 16 ₽ | ||
CD74HC132M96E4 Texas Instruments | 19 ₽ | ||
CD74HC132M96E4 Texas Instruments | по запросу |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | HC132M |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 70 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | 5.2/-5.2 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | Yes |
Technology Family | HC |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 27 нс |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD74HC132 (8)
- CD74HC132E CD74HC132EE4 CD74HC132M CD74HC132M96 CD74HC132M96E4 CD74HC132M96G4 CD74HC132ME4 CD74HC132MT
- Semiconductors > Logic > Gate > NAND Gate
