Datasheet Texas Instruments BQ2005STR — Даташит
СерияBQ2005
МодельBQ2005STR
Импульсное зарядное устройство NiCd/NiMH аккумуляторов для последовательной зарядки двух аккумуляторных блоков 20-SOIC от -20 до 70
Fast-Charge IC for Dual-Battery Packs datasheet
PDF, 657 Кб, Версия: A, Файл опубликован: 25 июл 2000
24 предложений от 15 поставщиков
Battery Charge Management Switch-mode NiCd/NiMH Battery Charger for Sequential Charging Of Dual Battery Packs Fast Charge Management NiCD/NiMH 2000mA 20Pin SOIC...
LIXINC Electronics
BQ2005STR
от 44 ₽
BQ2005STR
208 ₽
Akcel
BQ2005STR
от 301 ₽
HXD Co.
BQ2005STR
309 ₽
Pin2020
Package TypeDWDW
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
Маркировка-D2005S
Width (мм)7.57.5
Length (мм)12.812.8
Thickness (мм)2.352.35
Pitch (мм)1.271.27
Max Height (мм)2.652.65
Absolute Vin (safety rating)(Max)(7 В
Battery Charge Voltage(Max)20 В
Cell ChemistryNiCd,NiMH
Charge Current(Max)2 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells1,2,3,4
Operating Vin(Max)5.5 В
Operating Vin(Min)4.5 В
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
Special FeaturesTemp Monitoring (Thermistor Pin)
USB FeatureN/A
  • U-507 Using the bq2005 to Control Fast Charge
    PDF, 241 Кб, Файл опубликован: 5 сен 1999
    The bq2005 is a fast-charge IC that provides comprehensive fast-charge control functions and high-speed switching power-control circuitry on a monolithic CMOS device. The bq2005 offers sequential charge management in dual-battery-pack applications. This application note describes the use of the bq2005 to control a current source to fast-charge NiCd or NiMH batteries. The bq2005 can also serve as t
  • Battery Charger Termination Issues With System Load Applied Across Battery (Rev. A)
    PDF, 151 Кб, Версия: A, Файл опубликован: 2 окт 2006
    Battery Charger Termination Issues With System Load Applied Across Battery While Charging
Серия: BQ2005 (5)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ2005STR
