Datasheet Texas Instruments OPA2541SMQ — Даташит
СерияOPA2541
МодельOPA2541SMQ
Двойной операционный усилитель высокой мощности 8-TO-3 от -40 до 125
Dual High Power Operational Amplifier datasheet
PDF, 155 Кб, Файл опубликован: 27 сен 2000
20 предложений от 15 поставщиков
Микросхема Буферный усилитель, IC, Operational Amplifier, DUAL, BIPOLAR/JFET, CANF, 8Pin, METAL
OPA2541SMQ
от 27 370 ₽
ЭИК
OPA2541SMQ
от 82 451 ₽
OPA2541SMQ
OPA2541SMQ
Pin88
Package TypeLMFLMF
Industry STD TermTO-CANTO-CAN
JEDEC CodeO-MBCY-WO-MBCY-W
Package QTY11
CarrierTUBETUBE
МаркировкаOPA2541SMQOPA2541
Width (мм)25.425.4
Length (мм)38.8638.86
Thickness (мм)7.117.11
Pitch (мм)6.356.35
Max Height (мм)7.627.62
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)95 дБ
CMRR(Typ)106 дБ
GBW(Typ)1.6 МГц
Input Bias Current(Max)50 pA
Iq per channel(Max)25 мА
Iq per channel(Typ)20 мА
Количество каналов2
Offset Drift(Typ)15 uV/C
Рабочий диапазон температурот -40 до 125,-55 до 125 C
Output Current(Typ)7000 мА
Package GroupTO-3
Package Size: mm2:W x L8TO-3: 974 mm2: 25.4 x 38.35(TO-3) PKG
Rail-to-RailNo
Slew Rate(Typ)8 V/us
Total Supply Voltage(Max)80 +5V=5, +/-5V=10
Total Supply Voltage(Min)20 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)1 мВ
  • Mounting Considerations for TO-3 Packages
    PDF, 73 Кб, Файл опубликован: 27 сен 2000
    Proper mounting of TO-3 packages is required to assure rated performance and reliability. Although the procedures are simple, ignoring them can result in poor performance and catastrophic failure of the device.
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA2541SMQ
