Datasheet Texas Instruments SN65HVD24DRG4 — Даташит
СерияSN65HVD24
МодельSN65HVD24DRG4
Расширенный синфазный трансивер RS-485 8-SOIC от -40 до 85
SN65HVD2x Extended Common-Mode RS-485 Transceivers datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 18 ноя 2016
Чип интерфейса, Single Transmitter/Receiver RS-485 8Pin SOIC T/R
SN65HVD24DRG4
52 ₽
SN65HVD24DRG4
205 ₽
SN65HVD24DRG4
727GS
SN65HVD24DRG4
Package TypeD
Package QTY2500
МаркировкаVP24
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Common Mode Range-20 to 25
DuplexHalf
Fail SafeOpen,Short
Fault Protection-27 to 27 В
HBM ESD16 kV
ICC(Max)14 мА
IEC 61000-4-2 ContactN/A +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes256
Signaling Rate(Max)3 Mbps
Supply Voltage(s)(Nom)5 В
  • Evaluation Modules & Boards: SN65HVD22EVM
    SN65HVD22EVM Evaluation Module
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • Use Receiver Equalization to Extend RS-485 Data Communications*
    PDF, 1.6 Мб, Файл опубликован: 6 июл 2004
    System designers can use receiver equalization to extend their RS-485 data transmission applications in terms of longer cable distances or higher signaling rates. This application report discusses the benefits of using fixed receiver equalization for specific combinations of signaling rate, cable type, and node-to-node distance. Examples showing discrete implementations and integrated solutions ar
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
На английском языке: Datasheet Texas Instruments SN65HVD24DRG4
