Datasheet Texas Instruments LM4128BQ1MFX1.8/NOPB — Даташит
Серия | LM4128-Q1 |
Модель | LM4128BQ1MFX1.8/NOPB |
SOT-23 Источник опорного напряжения серии Precision Micropower 5-SOT-23 от -40 до 125
LM4128/LM4128Q SOT-23 Precision Micropower Series Voltage Reference datasheet
PDF, 1.0 Мб, Версия: E, Файл опубликован: 29 мар 2013
![]() 10 предложений от 10 поставщиков Опорный чип напряжения, V-Ref Precision 1.8V 20mA Automotive 5Pin SOT-23 T/R | |||
LM4128BQ1MFX1.8/NOPB Texas Instruments | 59 ₽ | ||
LM4128BQ1MFX1.8/NOPB Texas Instruments | 93 ₽ | ||
LM4128BQ1MFX1.8/NOPB Texas Instruments | по запросу | ||
LM4128BQ1MFX1.8/NOPB | по запросу |
Pin | 5 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | R6AB |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
Initial Accuracy(Max) | 0.1,0.2,0.5,1 % |
Iout/Iz(Max) | 20 мА |
Iq(Max) | 100 uA |
Iq(Typ) | 60 uA |
LFN 0.1-10Hz(Typ) | 170 ОјVpp |
Package Group | SOT-23 |
Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Pin/Package | 5SOT-23 |
Rating | Automotive |
Shutdown Current(Typ) | 3 uA |
Special Features | Enable pin |
Temp Coeff(Max) | 100,75 ppm/ degree C |
VO | 1.8,2.048,2.5,3,3.3,4.096 В |
Vin(Max) | 5.5 В |
Vin(Min) | 2.2 В |
- AN-1984 LM57 Temperature Switch vs Thermistors (Rev. C)PDF, 83 Кб, Версия: C, Файл опубликован: 1 май 2013
This application report compares the system design and performance advantages of sensing with TexasInstruments LM57 CMOS integrated circuit sensor as compared to a thermal-resistant (thermistor) sensorcircuit.
Серия: LM4128-Q1 (48)
- LM4128AQ1MF1.8/NOPB LM4128AQ1MF2.0/NOPB LM4128AQ1MF2.5/NOPB LM4128AQ1MF3.0/NOPB LM4128AQ1MF3.3/NOPB LM4128AQ1MF4.1/NOPB LM4128AQ1MFX1.8/NOPB LM4128AQ1MFX2.0/NOPB LM4128AQ1MFX2.5/NOPB LM4128AQ1MFX3.0/NOPB LM4128AQ1MFX3.3/NOPB LM4128AQ1MFX4.1/NOPB LM4128BQ1MF1.8/NOPB LM4128BQ1MF2.0/NOPB LM4128BQ1MF2.5/NOPB LM4128BQ1MF3.0/NOPB LM4128BQ1MF3.3/NOPB LM4128BQ1MF4.1/NOPB LM4128BQ1MFX1.8/NOPB LM4128BQ1MFX2.0/NOPB LM4128BQ1MFX2.5/NOPB LM4128BQ1MFX3.0/NOPB LM4128BQ1MFX3.3/NOPB LM4128BQ1MFX4.1/NOPB LM4128CQ1MF1.8/NOPB LM4128CQ1MF2.0/NOPB LM4128CQ1MF2.5/NOPB LM4128CQ1MF3.0/NOPB LM4128CQ1MF3.3/NOPB LM4128CQ1MF4.1/NOPB LM4128CQ1MFX1.8/NOPB LM4128CQ1MFX2.0/NOPB LM4128CQ1MFX2.5/NOPB LM4128CQ1MFX3.0/NOPB LM4128CQ1MFX3.3/NOPB LM4128CQ1MFX4.1/NOPB LM4128DQ1MF1.8/NOPB LM4128DQ1MF2.0/NOPB LM4128DQ1MF2.5/NOPB LM4128DQ1MF3.0/NOPB LM4128DQ1MF3.3/NOPB LM4128DQ1MF4.1/NOPB LM4128DQ1MFX1.8/NOPB LM4128DQ1MFX2.0/NOPB LM4128DQ1MFX2.5/NOPB LM4128DQ1MFX3.0/NOPB LM4128DQ1MFX3.3/NOPB LM4128DQ1MFX4.1/NOPB
- Semiconductors > Power Management > Voltage Reference > Series Voltage Reference
