Datasheet Texas Instruments DRV83053PHP — Даташит
Серия | DRV8305 |
Модель | DRV83053PHP |
Трехфазный драйвер затвора с тремя встроенными шунтирующими усилителями тока 48-HTQFP от -40 до 125
DRV8305 Three Phase Gate Driver With Current Shunt Amplifiers and Voltage Regulator datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 25 фев 2016
![]() 17 предложений от 10 поставщиков Драйвер электродвигателя, Motor / Motion / Ignition Controllers & Drivers Three Phase Gate Driver with Three Integrated Current Shunt Amplifiers 48-HTQFP... | |||
DRV83053PHP Texas Instruments | 251 ₽ | ||
DRV83053PHP Texas Instruments | 324 ₽ | ||
DRV83053PHP Texas Instruments | 466 ₽ | ||
DRV83053PHP Texas Instruments | от 711 ₽ |
Pin | 48 |
Package Type | PHP |
Industry STD Term | HTQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 250 |
Carrier | TUBE |
Маркировка | DRV83053 |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Additional Features | Failure Detection,SPI Management I/F,VDS Monitoring,Watchdog Timer |
Control I/F | PWM (6x/3x/1x) |
Current Sense Amps | 3 |
Gate Drive | 1 A |
Number of Half Bridges | 3 |
Package Group | HTQFP |
Package Size: mm2:W x L | 48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG |
Rating | Catalog |
Vs(Max) | 45 В |
Vs(Min) | 4.4 В |
- Evaluation Modules & Boards: BOOSTXL-DRV8305EVM
DRV8305N 3-Phase Motor Drive BoosterPack Evaluation Module
- Understanding IDRIVE and TDRIVE in TI Motor Gate Drivers (Rev. A)PDF, 1.2 Мб, Версия: A, Файл опубликован: 11 май 2016
The motor gate driver is an integrated circuit (IC) that primarily deals with enhancing external power MOSFETs to drive an electric motor. The gate driver acts as an intermediate stage between the logic-level control inputs and the power MOSFETs. The gate driver must be flexible enough to accommodate a wide variety of external MOSFETs and external system conditions.Texas Instrument’s IDRIVE - Sensored 3-Phase BLDC Motor Control Using MSP430PDF, 199 Кб, Файл опубликован: 20 июл 2011
Brushless DC (BLDC) motors are electronically commutated motors that offer many advantages over brushed DC motors and, therefore, are becoming very popular industrially and commercially. This application report discusses a sensored 3-phase BLDC motor control solution using MSP430в„ў as the motor controller. Hall sensors are used to detect the rotor position and close the commutation loop. Both open - Shelf-Life Evaluation of Lead-Free Component FinishesPDF, 1.3 Мб, Файл опубликован: 24 май 2004
The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: DRV8305 (6)
- DRV83053PHP DRV83053PHPR DRV83055PHP DRV83055PHPR DRV8305NPHP DRV8305NPHPR
- Semiconductors > Motor Drivers > Brushless DC (BLDC) Drivers > Brushless DC Gate Drivers
