Datasheet Texas Instruments TLV2252IDG4 — Даташит
Серия | TLV2252 |
Модель | TLV2252IDG4 |
Двойной низковольтный операционный усилитель малой мощности Rail-To-Rail 8-SOIC от -40 до 125
Advanced LinCMOS Rail-to-Rail Very Low-Power Op Amps Very Low-Power Operational datasheet
PDF, 2.1 Мб, Версия: D, Файл опубликован: 12 авг 2006
![]() 9 предложений от 9 поставщиков Микросхема Операционный усилитель, Dual ail-To- ail Low-Voltage Low Power Operational Amplifier 8-SOIC -40℃ to 125℃ | |||
TLV2252IDG4 Texas Instruments | 39 ₽ | ||
TLV2252IDG4 Texas Instruments | 90 ₽ | ||
TLV2252IDG4 | по запросу | ||
TLV2252IDG4 Texas Instruments | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 75 |
Carrier | TUBE |
Маркировка | V2252I |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | High Cload Drive |
Архитектура | CMOS |
CMRR(Min) | 70 дБ |
CMRR(Typ) | 83 дБ |
GBW(Typ) | 0.2 МГц |
Input Bias Current(Max) | 60 pA |
Iq per channel(Max) | 0.0625 мА |
Iq per channel(Typ) | 0.035 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 0.5 uV/C |
Output Current(Typ) | 8 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 0.12 V/us |
Total Supply Voltage(Max) | 8 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 19 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 1.5 мВ |
- Solid State Voice Recorder Using Flash MSP430PDF, 101 Кб, Файл опубликован: 25 янв 2001
The promise of cost-effective re-programmable MSP430 MCU systems has recently come to fruition with the integration of In-System Programmable (ISP) flash memory. Firmware delivered just in time during manufacturing, updateable code in field-deployed systems, and the elimination of discrete EEPROMs are now design realities. This application report demonstrates the flexibility of in-system programma - Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2252 (8)
- TLV2252CP TLV2252ID TLV2252IDG4 TLV2252IDR TLV2252IDRG4 TLV2252IP TLV2252QD TLV2252QDR
