Datasheet Texas Instruments OPA241UA/2K5G4 — Даташит
Серия | OPA241 |
Модель | OPA241UA/2K5G4 |
Операционные усилители MicroPower с однополярным питанием 8-SOIC от -40 до 85
Single-Supply, MicroPower Operational Amplifiers datasheet
PDF, 1.1 Мб, Файл опубликован: 27 сен 2000
![]() 12 предложений от 12 поставщиков Микросхема Операционный усилитель, OP Amp Single GP R-R O/P 18V/36V 8Pin SOIC T/R | |||
OPA241UA/2K5G4 Texas Instruments | 199 ₽ | ||
OPA241UA/2K5G4 Texas Instruments | 554 ₽ | ||
OPA241UA/2K5G4 Texas Instruments | по запросу | ||
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | OPA | 241UA |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | High Cload Drive |
Архитектура | Bipolar |
CMRR(Min) | 100 дБ |
CMRR(Typ) | 124 дБ |
GBW(Typ) | 0.035 МГц |
Input Bias Current(Max) | 20000 pA |
Iq per channel(Max) | 0.038 мА |
Iq per channel(Typ) | 0.027 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 0.4 uV/C |
Output Current(Typ) | 24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 0.01 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 45 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.25 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA241 (8)
- OPA241PA OPA241PAG4 OPA241UA OPA241UA/2K5 OPA241UA/2K5E4 OPA241UA/2K5G4 OPA241UAE4 OPA241UAG4
