Datasheet Texas Instruments UC2907DWG4 — Даташит
Серия | UC2907 |
Модель | UC2907DWG4 |
Контроллер распределения нагрузки 16-SOIC от -40 до 85
Load Share Controller datasheet
PDF, 351 Кб, Версия: C, Файл опубликован: 9 янв 2002
Купить UC2907DWG4 на РадиоЛоцман.Цены — от 289 до 465 ₽ 13 предложений от 9 поставщиков Controller 4.5V to 35V 16Pin SOIC Tube | |||
UC2907DWG4 Texas Instruments | 289 ₽ | ||
UC2907DWG4 Texas Instruments | 393 ₽ | ||
UC2907DWG4 Texas Instruments | 465 ₽ | ||
UC2907DWG4 | по запросу |
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 40 |
Carrier | TUBE |
Маркировка | UC2907DW |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Operating Supply Current | 6 мА |
Operating Supply(Max) | 35 В |
Operating Supply(Min) | 4.5 В |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG |
Rating | Catalog |
Share Bus | Single-Ended |
Special Features | On-Board Reference |
Startup Current | 3000 uA |
- Evaluation Modules & Boards: UCC39002EVM
UCC39002 Evaluation Module
- U-129 UC3907 Load Share IC Simplifies Parallel Power Supply DesignPDF, 251 Кб, Файл опубликован: 5 сен 1999
The UC3907 family of Load Share Controller ICs provides all the necessary features to allow multiple independent power modules to be paralleled, so each module supplies only its proportionate share to total load current. Many power supply manufacturers have found it economically feasible to make standard modular power supplies which are easily paralleled for higher current applications. If speci
Серия: UC2907 (7)
- UC2907DW UC2907DWG4 UC2907DWTR UC2907DWTRG4 UC2907J UC2907N UC2907NG4
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Load Share
