Datasheet Texas Instruments UC1875L883B — Даташит
Серия | UC1875 |
Модель | UC1875L883B |
Резонансный регулятор фазового сдвига 28-LCCC от -55 до 125
Phase Shift Resonant Controller datasheet
PDF, 5.7 Мб, Версия: C, Файл опубликован: 24 май 2007
Купить UC1875L883B на РадиоЛоцман.Цены — от 5 179 до 7 491 ₽ 8 предложений от 8 поставщиков Soft Sw PWM Cntrlr 4Out PH SHIFT RES 1MHz 28Pin CLLCC Tube | |||
UC1875L883B Texas Instruments | 5 179 ₽ | ||
UC1875L883B Texas Instruments | 7 179 ₽ | ||
UC1875L883B Texas Instruments | по запросу | ||
Pin | 28 | 28 | 28 | 28 |
Package Type | FK | FK | FK | FK |
Industry STD Term | LCCC | LCCC | LCCC | LCCC |
JEDEC Code | S-CQCC-N | S-CQCC-N | S-CQCC-N | S-CQCC-N |
Package QTY | 1 | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE | TUBE |
Маркировка | UC1875L/ | 5962- | 883B | 9455501M3A |
Width (мм) | 11.43 | 11.43 | 11.43 | 11.43 |
Length (мм) | 11.43 | 11.43 | 11.43 | 11.43 |
Thickness (мм) | 1.83 | 1.83 | 1.83 | 1.83 |
Pitch (мм) | 1.27 | 1.27 | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 | 2.03 | 2.03 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать |
Control Method | Current,Feedforward,Voltage |
Duty Cycle(Max) | 100 % |
Frequency(Max) | 1000 kHz |
Package Group | LCCC |
Package Size: mm2:W x L | 28LCCC: 131 mm2: 11.43 x 11.43(LCCC) PKG |
Rating | Military |
Special Features | Error Amplifier,Soft Start,Soft Switching,Synchronization Pin |
Topology | Full-Bridge |
UVLO Thresholds On/Off | 10/7 В |
Vin(Max) | 20 В |
Vin(Min) | 9.25 В |
RoHS | See ti.com |
- Phase Shifted Full Bridge, Zero Voltage Transition Design Considerations (Rev. A)PDF, 393 Кб, Версия: A, Файл опубликован: 22 янв 2011
This Application Note will highlight the design considerations incurred in a high frequency power supply using the Phase Shifted Resonant PWM control technique. An overview of this switching technique including comparisons to existing fixed frequency non-resonant and variable frequency Zero Voltage Switching is included. Numerous design equations and associated voltage, current and timing waveform
Серия: UC1875 (6)
- 5962-9455501M3A 5962-9455501MRA UC1875J UC1875J883B UC1875L UC1875L883B
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
